Cam Help
Old 05-29-2009, 10:42 AM
Texass683's Avatar
Default Cam Help
Ok so I am bone stock except for an airlid. I want to start modding a little bit and collecting pieces along the way so that I can do it all at once. Would this be a good cam for a car that is also used as a daily driver?
Comp Cams 224/228 @ .050 duration , .595/.615 lift , 114 LS.
Or this one ... 225/227 @.50, .571 lift, 112 lobe-center angle
I dont know much about cams but have been told something between the 224/228 range is good for a DD car.
Thanks
Old 05-29-2009, 10:59 AM
TRANS-DAD's Avatar
Hey TEX man cam's are like chick's!, everybody got a diff. op. of perfect!!
but you'll get more responses if you give more info like M6 or A4, you said bone stock
ex lid but do you plan on full exahust? or other mods? Do you want a sleeper or
do you wan't a nasty big thump'n cam?
Old 05-29-2009, 01:55 PM
Texass683's Avatar
its an M6 and i want power but not anything rough. I want about 50hp if possible but kind of a sleeper sound. So if any of those two cams will work that will be great. Thanks.
Old 05-29-2009, 03:09 PM
Super Speed's Avatar
The 224/228 would probably be good for you if you don't want to hear the cam very much! As for drivability I'm sure you could do a 228/228 and it would drive like stock! With the right tuner of course!
Old 05-29-2009, 03:29 PM
nastychevelle's Avatar
stall then cam
Old 05-29-2009, 07:38 PM
scites's Avatar
nasty it is a M6 car so a stall would be hard to fab up into it..lol
Old 05-29-2009, 08:37 PM
damn haha i do that all the time!!!! i guess thats what i get for skimming the thread
Old 05-29-2009, 09:56 PM
99 ls1 z28's Avatar
i also am looking into a cam i have 4.10s, pacesetter LTs and catless y.I do want a cam that is going to make some noise and good power but still be a daily driver what would you suggest 228/228 i have no clue what thosse numbers mean so if you could fill me in a little i would apprcieate it
Old 05-30-2009, 08:39 AM
dre2013's Avatar
id go with the 224/228...99ls1z28 read the stickiez at the top of the forum, theyll answer ur questions
Old 05-30-2009, 09:44 AM
Hardtop's Avatar
Get a quality set of headers first.
Old 05-30-2009, 04:09 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I've done a few camshafts with stock manifolds, but I really like to see headers be in place prior to the camshaft. We've run a 220R camshaft & 220/224 camshaft with stock manifolds. Checkout the Pacesetter 1 3/4" long tubes, or the TSP 1 7/8" long tubes for the bang for the buck they're hard to beat.
http://www.texas-speed.com/shop/item...d=899&catid=45
http://www.texas-speed.com/shop/item...d=184&catid=45
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
