What can I do to make 500rwhp?
Old 05-30-2009, 12:20 PM
Pseudonym's Avatar
Default What can I do to make 500rwhp?
I would like to make about 500 hp and 500 ft lbs at the wheels. What would be the best way to do this without nitrous? H/C/I? turbo? supercharger? other mods? My budget is $6000. Is that enough or should I wait until I have more?
My car is an 1999 A4 trans am with an SLP lid, FTRA, and magnaflow catback, but I am willing to start over if I need to remove any of the mods.
Any suggestions are greatly appreciated.
PS I know I need to do something about the transmission and rear before I do major mods.
Old 05-30-2009, 12:24 PM
Bo White's Avatar
I know of a 408 local to me thats 24x/24x cam, ported 317 heads, FAST 90 through a 4L60 making 475/475 so it shouldnt be too hard with a set of aftermarket heads(AFRs/DARTs/TFS/whatever).
Old 05-30-2009, 12:26 PM
Hamrdown's Avatar
You won't get that power NA in a a4 unles it's a good sized stroker. I would go supercharger and boltons and call it good.
Old 05-30-2009, 12:28 PM
Super Speed's Avatar
For 6 g's you could get a used procharger and supporting mods and call it good 500+ rwhp
Pseudonym's Avatar
Thanks for the quick reply. Anyone else? Should have mentioned that I would prefer to keep the displacement at 5.7 liters.
Old 05-30-2009, 12:33 PM
Pseudonym's Avatar
Question
Thanks guys. I'll start looking into forced induction. What kind of power do you think I could make Hamrdown? My real goal is low 11s in the 1/4 mile. Is it possible?
Old 05-30-2009, 12:34 PM
therealcreeper's Avatar
if you want times, get a nice stall and some drag radials. quite a few people have hit high 11's with bolt-ons and a stall. then you can do heads/cam with the rest of the money.
Old 05-30-2009, 12:44 PM
Hamrdown's Avatar
500rwhp in a A4 is mid 10 sec territory. I ran in the 11s with boltons and a 4k stall with suspension mods and slicks.
Old 05-30-2009, 12:46 PM
Hamrdown's Avatar
A good stall,head,cam package will get you there reliably.
Old 05-30-2009, 01:13 PM
Bo White's Avatar
Right, the 408 I posted about runs 6.7s 1/8 mile full weight car.
Old 05-30-2009, 01:18 PM
nastychevelle's Avatar
this is what i would do
415 shortblock from schwanke 3300
l92 heads/intake kit from SD 1500
custom cam something like a 224/238 .609/.605 112+4 would be nice with prc duals and pushrods 750
that puts you at 5550
500+RWHP all motor
Old 05-30-2009, 03:34 PM
Pseudonym's Avatar
Glad I asked before I started wasting money on the wrong stuff. You guys are alot of help. Thanks for the info.
Old 05-30-2009, 03:50 PM
camarorat's Avatar
better start saving for a built trans while your at it. with that kind of power it's only a matter of time until she goes especially with the early models
Old 05-30-2009, 04:44 PM
Pseudonym's Avatar
I know. I've got a some money set aside for the tranny and rear end. I will be having those replaced before I start the motor work. I will probably also do a brake upgrade.
Old 05-30-2009, 10:14 PM
blkdkz28's Avatar
I think theres a thread on this somewhere...not sure if you can do what he did on 6k though...
Old 05-31-2009, 09:51 PM
Hamrdown's Avatar
I believe your referring to Patrick G's "recipe to 500 rwhp heads and cam" thread. It's an excellent read but it's for a M6 trans. That would equate to about 440-450rwhp in a stalled A4. Plus it definately wasn't cheap to achieve.
Old 06-01-2009, 01:16 AM
allngn_c5's Avatar
I'd wait until I had 16 grand vs 6 !! You can build the motor up but your trans is going to go, then your rear end will explode or vice versa. Do it right all at once. You build a motor to 500/500 to the wheels and your a4 tranny and stock diff are going to be the weakest links, aka ticking time bombs. You'll also need to look into a tire upgrade. Sticky tires that will hold that kind of power in a stalled auto will be expensive and won't last long. Drag radials will be decent. I have Nitto drags 305's in my m6 stroker and they hold once up to temp. Too much throttle though and first gear goes up in smoke. Second gear will hold WOT. Too badk I can't go WOT until I get a better fuel pump since I am going lean up top. Guessing the stocker has gotten tired since half her life she's been overworked feeding 400 rwhp or more. LOL Good luck doing it for 6 grand.
