228r cam with 59cc heads
im using a stock gm head gasket and stock pistons, do yall know if i will have any ptv clearence problems thought i would see what yall say before i give texas speed a call tomorrow. thanks greg
The question you should ask is (By how much will it clear?) and how much PTVC are you confident on running?
Also with that size of cam, high compression is not needed. IMO you should shoot for 11:1 which would give you comfortable PTVC and power benefit. That would require 62cc with .052 gasket or 61.5cc to be sure (if gasket a tad thicker), so I vote for 61.5cc max mill with the 228/228 112 LSA.
