Sealing intake rocker bolt..with what?
I have read blue locktite, teflon paste and high temp silicone. What did you use and why? What are the reputable shops using?
I just used high temp RTV on mine which is what my Jesel instructions called for. I wish I would have thought of the blue loctite gel - I had that sitting right here!
Thanks, Guys! I wonder what the cure time for the blue locktite paste is ?
**EDIT**
Looks like 6 hours... http://65.213.72.112/tds5/docs/242-EN.PDF
**EDIT**
http://www.siliconesolutions.com/prod/compare.php
I used thread sealing tape. Like the white tape you use for plumbing, but this is yellow and much thicker. You can get it at Home Depot. Its made for gasoline, kerosene, liquid propane, oil, etc. Curing time is zero.
