TSP 5.3L heads...change or not?
i will be ordering a custom grind cam and i was curious if i should change my heads or not. my current mods are:
TSP 5.3L 2.5 heads, TR224 cam, LS7 lifters, hardened pushrods, AR 1 & 7/8 headers with their ORY, gmmg, vengenace ported fast 92, NW 92 throttle body, ATI 10% underdrive pulley, yank PT 3800 2.0 str, 3.42 rear, etc.
i want to go with a more aggressive cam so i will get a custom grind one made for my needs. i am not sure if i should change the heads or not. i would like to stay under $2000 on the heads and i WILL use the stock rockers. the main reason why i am considering changing the heads is because i will need to upgrade my valvesprings. i have the updated 918's on, and while they are fine for my cam they can't handle too much more probably. for me i wouldn't mind pulling the heads to swap them out and sell these. my car is full weight and i do not want to flycut. i won't get a cam made until i know what heads i will run so everything matches. for the money that the heads cost, it isn't worth it to me if i gain a tenth. i want to get a solid gain if i go out and change the heads. what does everyone think?
