Head swap
Old 06-11-2009, 10:38 AM
driftpin's Avatar
Default Head swap
Just wondering if there is enough room to install the heads on an engine with an ARP stud kit without having to lower the engine at all? If not I'm going to just go with a bolt kit.
What are your ideas on the bolt kits, OEM or ARP?
Old 06-11-2009, 01:43 PM
conan's Avatar
I have arp head studs and I have removed my heads with out any problems.
Old 06-11-2009, 03:53 PM
driftpin's Avatar
Thanks a million.
Studs it is!!
Old 06-11-2009, 05:55 PM
conan's Avatar
Originally Posted by driftpin
Thanks a million.
Studs it is!!
You'll thank your self again if you have to remove the heads because you wont have to clean any coolant out of the threads in the block.
Old 06-12-2009, 12:14 AM
SOMbitch's Avatar
It can be tight in the cowl area but be careful and it's good as conan said.
