Which Heads?
Which Heads?
I'm thinking of adding heads to my 1999 trans am but i'm not sure which ones to go with. I was thinking of getting PCR stage 2.5 heads or TEA stage 2 heads. Which head do you think I should go with? I have a stock bottom end 346 with full bolt ons, 3600 vig stall and 3.73 gears. I don't have a cam but i plan on getting one in the 224-230 range, not to big of a cam. I plan on running NA.
Buy some cheap ls6 heads......Sometimes if you wait long enough and shop around enough you can get them cheap. A friend of mine got a set for 175, had a machinist who owed him a favor do 800 bucks of porting work for 250, and had heads that flowed better than heads that costs >2K
oh my god. if you don't know what your recommending, don't recommend it.
anytime someone is looking at heads, you really need to figure out what you want to spend. you can NOT get the same performance out of a budget casting and budget porting from a budget porter.
10 Second Sleeper Club
AFR --Been runnin them for 2 years with awesome results. Even swapped onto a forged 383 when my stock block grenaded. Sometimes goin cheap will cost you more in the long run. Good luck with your choice.
LS1Tech Premium Sponsor
This is a good thread. Your definately picking between two good sets of heads, and I have no doubt you'll be happy with either option. That being said here's what I can tell you about the PRC heads. They ship with your choice of valve sizes, and milling for the (currently on special) $1129 a pair price! With this you'll get a brand new set of 5.3l heads fully cnc ported with manley valves & the PRC double spring kit good to .660" lift. We've done tons & tons of combos with camshafts similar to what your discussing, just let my guys know what camshaft your looking to run & we'll custom mill your cylinder heads to meet your exact specs. This way you get exactly what your looking for the first time without paying extra for milling.
We have plenty of engine & chassis dyno data we can send you if you'd like more data about the PRC Stage 2.5 5.3l cylinder heads. Give us a call if we can help you in any way!!
Heads:
http://www.texas-speed.com/shop/item...id=84&catid=20
Heads Cam Combo Special:
http://www.texas-speed.com/shop/item...d=203&catid=47
Heads:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Just noticed your in Texas. If you'd like your welcome to setup a time to come spend a little bit of time with us on the engine dyno. We're always doing head testing & can spend some time with you showing different options.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
