cammed T/A not gaining speed?
Hey, i have a 2002 ws6, everything on it seems to be from Texas speed. I bought the car wrecked and got it fixed, so the motor was built when i got it, the cam sounds like either a ms3 or ms4, it has pacesetter long tubes with a 3in xpipe with dynamax dumps, i took the tb off and it has been ported, the heads are still the 241 heads so their stock but i don't know if they have had any work done to them. It had a hole in the passenger side of the xpype? maybe that was where it was tuned i don't know, it idles fine an has little drivability problems, it pulles hard and the power band don't seem to kick in untill around 3k rpm's and the revlimiter is at around 6600. My buddy raced it today, he has a 2002 formula with long tubes, everything else is stock, and stayed behind me by about a car or two, should it be doing better than this? it pulls hard but don't seem to be gaining speed like it should be, and suggestions would be appreciated.
it will bounce your head off the seat all the way to 4th gear but its just not putting it t the ground, i'll take it to the track and see what kinda times i get then i'll take it to get dynoed. Thanks for the help
