LS7 vs. LS1 lifter length
Just to verify something. The LS7 lifter is not longer, just the cup sits .06 higher than the stock LS1. This means when installing LS7 lifters, you will need a shorter length pushrod to stay within a resonable preload. Most likely a 7.35 or even a 7.325 pushrod will suffice depending on how much preload and valvetrain noise you want. As for optimum preload, the LS7 lifters is spec'd to be run between .06-.100 amount of preload or within that ballpark. Aftermarket lifters recommend different preloads, but this does not necessarily apply to the LS7's.
Why is the LS7 marketed as an LS1 replacement when it apparently raises preload to unacceptable levels when using pushrods fit to stock LS1 lifters. I did everything right when ordering my custom length rods, excpet I used a solid LS1 lifter under the impression the LS7 was identical. This blows...
Why do so many ask for pushrod length when the only way to know is to measure the pushrod length on the engine in question? Working on the internals of an engine and thinking that their are "stock" answers to these questions" shows an incredible ignorance.
Try that "one size fits all" at the pharmacy.
The following users liked this post:
Gen2-LT4 (03-10-2021)
The LS7 marketed as an LS1 replacement was an ingenious marketing ploy done by GM, as per the owner of where I get my parts at. The true LS7 have a raised cup by .06 and it is not a stock replacement. The "LS7" LS1 direct replacement is an overflow of LS6 lifters that GM wanted to get rid of and make some money. There is no stock replacement LS1 parts in the LS7 engine not one part. Now if you want to make a difference the buy the CTSV lifters you can rev those to 8K rpm no issues, but they go for 500+ dollars. For the monye I was going to spend on the "LS7" stock replacements i spend a little more and got the Comp type "R" Pro Magnum and I have piece of mind.
LS1TECH & Trucks Sponsor
The Caddy race lifters actually sell for just under $250, not over $500.
If you have any questions please feel free to hit us up in a pm or even call, we'll be glad to help you out with any answers you are looking for. We'll be glad to verify anything you hear from your parts guys if you think you might want a 2nd opinion
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
I believe you have been a little misinformed. There is no marketing ploy, and you seem to a a little confused as to how it all works. The LS7 lifters are THE LS1 replacement, period. It is not an overflow of LS6 lifters that are used in a money making marketing ploy as you said, they are not any different that whatever you are calling "true LS7 lifters" because it is the exact same lifter. Please don't make public claims of such things as it is a rather slanderous accusation towards those of us who market the parts, and it is outright incorrect information. Both the LS7 and LS1 replacement lifters are the same part, and there are actually several shared replacement parts between the two, quite contrary from the "not one part" claim you make. Bearings, lifters, head bolts, freeze plugs, gaskets, sensors, etc are all the exact same parts.
