Why aren't 396 LS1 Strokers popular?
It seems 383 strokers (4.000" stroke) are very popular if your going to stroke a stock LS1 block, but why don't you see much about a 396 CU IN stroker?
3.903" bore & 4.125" stroke gives you a 396.
From the research that I have done so far, all you need is a 4.125 stroke crank (which Lunati makes) and you have to notch a few spots in the block to allow for piston/rod clearance, the same thing you need to do for a 427 engine.
Why go 383 when you can go 396 and get more torque? The costs are the same.
Is there something I'm missing here?
Bill
Bill
LS1Tech Co-Founder
that 3.903 to 4.125 ratio is very undersquare. Most builders prefer square (equal bore and stroke) or oversquare (more bore than stroke). Oversquare engines tend to rev quicker than undersquare engines also.
396ci is popular with LT1 engines because that is the biggest they can get.
Tony
Tony
Originally Posted by mattf2
can't you do a 396 oversquare too? (LS1)
I always thought another SS396 would be cool.
TSP has an Iron block 396 4.06" bore and 3.82" offset ground stock crank.
Cubes= (Bore*.5)^2*3.14*(# of cylinders)*(stroke)
Bill, just get a 6.0 block and bore it 0.030 then get a 4" crank. Call it a 396 or a 409!
I'm actually planning on the 4.030 bore 6.0L block and the 4" crank myself sometime down the road.
Originally Posted by Technoman64
Isn't there an old syaing there is no substitution for cubic inches. Or something like that
