Oil Pan Removal
Old 06-22-2009, 02:32 PM
01trans am's Avatar
Default Oil Pan Removal
Does anyone know if there is a write up on how to remove the pan with the engine still in the car. I did a search but couldnt find anything good to explain how to do it.
So if anyone has done it please give me some tips.
Thanks
JC
Old 06-22-2009, 04:01 PM
claytonisbob's Avatar
If you're trying to see if you left a rag in the engine, could you look through the oil drain plug (with a camera?) to check?
Old 06-22-2009, 04:33 PM
01ssreda4's Avatar
pull k member while holding motor up. the rest is very straight-forward. have fun, throw some poly motor mounts in while you have it off.
Old 06-22-2009, 08:32 PM
blkbird's Avatar
I removed the alternator, a/c (to get to the motor mount bolts) and supported the engine/tranny before i dropped the k member. Dont forget to unbolt the struts and spindle from lower control arm and unbolt the sterring from the top bolt.
Old 06-22-2009, 10:11 PM
SOMbitch's Avatar
Yeah....Have lotsa fun
