Need headgasket help!
Helping a friend put together his 383 and we are just about done, but he isnt sure what head gasket to use. He has a ls1 stroked to a 383. I assumed the bore is the same as stock since it was only honed? I am right? Would it use i guess a stock GM MLS gasket? He intends to run some boost between 15-20 lbs i believe. Let me know what gaskets it needs so we can order them already.
Thanks.
Thanks.
With those heads and that boost level, the GM MLS gaskets will be fine. You will need 2 of PN 12589226. We have them here: http://www.thunderracing.com/catalog...&sid=353#P2438
Thanks,
Shane
Thanks,
Shane
