LQ stroker questions
Old 06-23-2009, 07:15 PM
shawn_s's Avatar
Default LQ stroker questions
im starting to look into building an LQ stroker engein and i have a few questions. looking to end up with around a 400 CI engine.
would it be better to start with an LQ4 or and LQ9? i figure the block should be the same so it wouldnt really mater, just wanted to double check.
would it be easier/better/ make more sence to start with just a block or a complete engine?
any suggestions on which stroker kit to go with?
what sort of compression ratio should i be looking for? the car will probably be about a 90% street car 5% drag, 5% autocross so i definatly want to be able to run on pump gas.
with a 402-408 stroker, EFI victor jr. or super victor intake, heads, cam, full exhaust, ect. what kind of hp/tq numbers would i be looking at? i know this one is going to be hard to guess at but im just looking for a rough estimate. i have a rough goal in mind of hitting around the 500 hp and tq mark. if i end up alittle over or under im sure it will still be fun.
thanks in advance.
Old 06-23-2009, 09:11 PM
black01_WS6's Avatar
look for what ever is cheaper. I picked up a lq9 complete for cheap, otherwise I would just get a block, as you will be changing just about everything on it anyhow- no need to buy **** you are going to throw away, or not use.
you can hit 500 but it takes very heads, compression, and a good exhaust/ intake setup as a minimum. I am looking to build my 408 for right around 11.7 compression.
it seems like most of the guys making 500 are 11.5 or above with a few exceptions.
all in all you may be better off to buy a shortblock already done as it is hard to match some of the prices I have seen lately.
Old 06-25-2009, 04:44 PM
shawn_s's Avatar
thanks for the input.
i had heard something about anything over a 10 or 10.5 compresstion ratio needs a higher higher octain gas then what you can get at the pumps, anyone know anything about this?
and anyone have any other input?
Old 06-25-2009, 05:31 PM
you can run 12-1 on pump gas 93 octane. with the ethanol being put in the gas now I am going with 11.7-1 to be on the safe side.
If you are over 10.5-1 then I would run 93 all the time anyhow.
Old 06-25-2009, 06:50 PM
PAGregSS's Avatar
I'm running around 11.2:1 SCR on my 408 with no issues.
Old 06-28-2009, 03:50 PM
shawn_s's Avatar
thanks for the help guys, any input from anyone else?
Old 06-28-2009, 04:30 PM
Stroker_Bill's Avatar
i picked mine up as a built/assembled short block from SLP a few years back. now they are way less expensive. i run just under 12.1 in mine on pump gas (94) and theres no problems with it.
Old 06-28-2009, 04:54 PM
tatasta's Avatar
Where do you guys find pump gas at 93-94 octane? I pay attention to that wherever I go and never see anything over 91 anymore. I do use toluene to get 96 if I feel like spending $12/gallon for it. The price for toluene is a whole issue to rant about.
Old 06-28-2009, 04:56 PM
ohio, mich, indiana.
Old 06-29-2009, 09:00 PM
tatasta's Avatar
Damn, must be nice. Jealous. The MAN in Nevada is keepin' us down!
I'm sure there isn't enough of a market here.
