Whining noise after H/C install
Old 11-12-2003, 10:30 PM
01TA's Avatar
Default Whining noise after H/C install
I have had a whine noise since I install my heads, cam, YT rocker and pulley. It sounds like a very quiet geardrive, happens through out rpm range. It sound pretty cool realy. But it has me concerned.
Could it be normal, I have not heard any other LS1s with a cam or YT rockers?
These are my ideas, waterpump bearing, Alt. bearing, Idler pulley or maybe just normal noise for the yella terra rockers. any thoughts.
__________________
2001 TA M6 Black
ENGINE: Absolute Speed Stage II, TR224/114, YT 1.7 Rockers, Katech oil pump & Jwiss chain, Shaner S2 TB, ASP pulley, Lid, FTRA, 160' Stat.
Old 11-12-2003, 10:44 PM
jrp
SN95 Director
jrp's Avatar
how long has it been since the install? you'll definately have more vavletrain noise with new springs, its normal. YT rockers usually run softer but there should still be a normal valvetrain noise that sounds kinda like a sewing machine.
Old 11-13-2003, 06:48 PM
01TA's Avatar
The install was a few weeks and around 100 miles ago, I don't drive the car much, I can not tell if it is coming from the front of the motor or under the valvecovers. it is hard to hear at idle I need to rev the motor a little to hear it above all the other noises(sewing machine, ticks, knocks ect.)
It is inbetween a whine and a whistle sound. Anyone else have any thoughts????
Also I was thinking of taking the drivebelt off and starting it to see if it is internal or a belt driven accesory such as the waterpump. Is there anyway I could hurt the motor running it with out the belt for 10-20 seconds??
Old 11-13-2003, 07:29 PM
JoeyGC5's Avatar
Make sure the engine temp is right around if not a little below 200 degrees, well just don't let it get to hot. Keep a battery charger handy and good luck
Old 12-12-2003, 11:50 PM
bambamz's Avatar
Did you ever fiqure the noise out? I have a H& C with YT's and am having the same issues..
Old 12-13-2003, 02:22 PM
01TA's Avatar
No I hav'nt, I did pull the belt and the noise is still there so it is internal. Some day I will pull the YTs and put the stockers back in just to see if it goes away.
Old 12-13-2003, 02:49 PM
bambamz's Avatar
Well so far here is what I have done:
Pulled the belts, and checked all pulleys and pumps....No Luck!
Pulled the intake (since I have the Holley) and regasketed, and re RTV'd...No Luck!
Pulley the valve covers and reshimmed all YT's...No Luck!
Funny thing is at cold start..I dont hear it for about 3 mins...Then it starts and goes with the RPM's????
I have no clue but its driving me nutz...
99Z A4 with PP Stg 2, Big Cam, YT's, Holley Intake, ASP UDP, 80mm TB, all suspension bolt ons. 3500 Yank, 3.73, And afew others....
Old 12-14-2003, 07:50 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
My car did that too right after heads and cam were installed. However, when my wife got out of the car all the whinning stopped.
Old 12-15-2003, 05:45 AM
bambamz's Avatar
Lol! Lol!
Old 12-15-2003, 06:16 AM
Hannibal's Avatar
By chance do you have a ported TB? I originally had the stock unit on when I did my installed my heads. To get a little more air into the engine to compliment the heads - I add a ported TB and right away noticed the whistle. It would eventually go away as the motor warmed up but it was very present at first.
Just an idea.
Old 12-15-2003, 10:59 AM
bambamz's Avatar
Actually I have the 80mm BBK...Mine doesnt whistle from a cold start but begins to once temp get to around 140ish. I think it might be my IAC. I have heard from a few sources that if they go bad they whistle
Old 12-30-2003, 01:03 PM
01TA's Avatar
Any update, Have you figured out what that noise is?
Old 12-30-2003, 04:21 PM
bambamz's Avatar
i SURE DID! Part of the noise was the IAC which I replaced. 60 bucks.
The other part was my Polished Holley Intake. When I reinstalled everything I re-RTV sealed the Intake to header area but forgot to seal the Intake access panell underneth with RTV. Once it warmed up A leak would begin( due to the expansion of metal. Problem for me now solved. Thanks for your help.
Quick Reply: Whining noise after H/C install
