Bye GM water pump , welcome Meziere .. but which one !!!
Hello ,
my GM water pump need to be replaced .. so I'm thinking of Meziere .. but there are three types ..
Meziere Bolt On LS1-LS6 Pump - WP319R
Meziere LS1-LS6 Heavy Duty Race Pump - WP119RHD
Meziere LS1-LS6 Race Pump - WP119R
My car is only bolt-ons and may expose to some H/C in the next two months ..
Your advise and help
If you want to keep your heat you have to get the WP319R model, and also must have the "LS" on the pump not the "LS1" logo on it if you ever plan on going to a FAST 90/90 or bigger as the throttle will hit the top of the "LS1" style Meziere pumps, unless you just want to notch it later.
wp319 here
came with the hose fittings that fit just fine.
not sure...but i'm pretty sure mine says LS1 on it...and it clears my FAST 90 just fine.
by the way, search for my write up on the install process...not a step by step as LS1howto has it. but i put some helpful hints and tricks that made it easier.
So i'm understanding all of you using wp319 and no problems .. I'm going with it ..
but I have seen in Summit Racing a required parts such as Mazarie Adapter .. shall I pick one ? .. which size for Camaro 2001 ?
