Are all GM crankshafts the same
Old 07-02-2009, 03:54 PM
racecar's Avatar
Default Are all GM crankshafts the same
I'm looking at buying a used GM LS crankshaft 3.622 stroke with a 24X timing wheel.
Are all the 3.622 stroke cranks the same? I don't know if I am getting an LS1 or an LS6, is there a difference in metals or design, or anything???
Old 07-02-2009, 04:33 PM
LS1Formulation's Avatar
I just bought an LS6 crank from Katech. It's functionally identical to an LS1 crank. What I don't know is if GM used a different casting for 5.3 or 6.0 truck engines due to the piston weight being different in those engines. Maybe someone with a little more knowledge can chime in here.
Old 07-03-2009, 01:29 AM
racecar's Avatar
All LS1 or LS6 cranks should be the same? Maybe the truck engines have more counterweight.
Old 07-03-2009, 01:48 AM
blackLS1m6's Avatar
They are the same but the truck cranks had a wider rear seal surface.
Old 07-03-2009, 09:38 AM
got-a-ls1's Avatar
truck cranks are also not drilled like the ls1 cranks in the journals, if memory serves correctly... which means they are heavier, but not necessarily stronger.
Old 07-04-2009, 01:13 PM
1FastBrick's Avatar
Cranckshafts with the 12552216 casting number = Same crankshafts but machined differently for each application. All interchangeable just be sure to have it ballanced for your application.
https://ls1tech.com/forums/11028189-post4.html
https://ls1tech.com/forums/generatio...lq9-crank.html
Old 07-05-2009, 11:29 PM
racecar's Avatar
Thanks Guys, good info. Now I know what to ask for, As long as it has the hole drilled through the journals, it's will work for me..
Old 07-06-2009, 01:00 AM
1FastBrick's Avatar
You mean the 1 inch hole gundrilled through the center of the mains... LOL Cranks usually have holes drilled through the journals for oiling
Old 07-07-2009, 11:56 PM
racecar's Avatar
Yes, We do need oil holes. The crank grind shop said it has the holes, yes the big ones.
Thanks Everyone for the info.
Quick Reply: Are all GM crankshafts the same
