LS6 Cam dyno graph
Old 11-13-2003, 04:23 PM
SSEUL8R's Avatar
Default LS6 Cam dyno graph
Well... I finally figured out how to get my graph on the web. So here it is. This is with the mods in my sig. Pretty much the numbers I was hoping for, but it detonating above 4000 or so as you can see. Why does my car get so lean? It's on stock tuning, but I wouldnt figure that it would get so lean like that.
Old 11-13-2003, 04:27 PM
Aidan's Avatar
How many miles since the cam change??
Sometimes the computers need time to relearn and will adjust.
Id say get a predator or ls1edit and do some tuning
Old 11-13-2003, 04:30 PM
whiteLS1's Avatar
i would firgure out how to get it to stop running lean and ASAP because my friends car was like that on the dyno and now it has a crack piston ring and it smoke very bad.
nice number though
Old 11-13-2003, 04:43 PM
jrp
SN95 Director
jrp's Avatar
just get a basic tune from a local dyno tune or if you have access to edit then use that or use a MAFT.
Old 11-13-2003, 05:05 PM
SSEUL8R's Avatar
Well what can i do easily for now until i can get my car tuned? I have had this setup for about 10k miles now, I'm worried that runnin lean like that has hurt my engine. It doesnt smoke or anything, but now my #1 priority is getting richened up some. Any ideas?
Old 11-13-2003, 05:13 PM
strokedls1's Avatar
On the short term you could replace the fuel filter. My car richened up a little bit as seen on autotap logs after I switched it at only 27k miles. You need to do some ls1 editing to get those inline though. I would not do any wot runs until you get this resolved.
Old 11-13-2003, 05:22 PM
jrp
SN95 Director
jrp's Avatar
see if anyone local to you has a MAFT translator you can use to richen up your **** until you can get a tune.
Old 11-13-2003, 06:55 PM
jmX
jmX's Avatar
If you have modified your maf at all, put a stock one back one. My girlfriend had a gutted out stock MAF on hers and it only made 304. I put a granatelli (didnt have a stock one laying around) and it went back to normal...no detonation, normal A/F curve.
Old 11-13-2003, 07:39 PM
LS1Tech Sponsor
Slowhawk's Avatar
Get a MAFT ASAP and richen it up.You can get them cheap in the for sale section.
Old 11-14-2003, 06:55 AM
WS6snake-eater's Avatar
man that cam doesn't even come alive until after 4000rpm. Trust me I have one. You are missing a whole lot of peak power. MAFT or tune.
Quick Reply: LS6 Cam dyno graph
