(insider info) carbarated intake by Edelbrook to be released in january
Old 11-15-2003, 04:10 PM
BIG PD's Avatar
Default (insider info) carbarated intake by Edelbrook to be released in january
Had a Edelbrock salesman come in the shop on tuesday and show my boss the new catalog for next year. i got a glimpse of the catalog and sure enough they have developed a retro kit for the ls1 engine. you will now be able to put a carbarator on your ls1. i asked who there general target for this product was because i don't think people will spend a bunch of money to get away from carbarated and he said people that have ls1's in the there custom cars. so i was like cool. but yah it should be out around the beginning of next year.
Old 11-15-2003, 04:59 PM
DaleMX's Avatar
Thats cool. I might be intrested in one. If its designed correctly it can flow a shitload of air.
Old 11-15-2003, 05:29 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Sounds nice...I'm looking forward to seeing it in person.
Speaking of carb'd LS1 intakes...there is another one coming from GM Performace next year. It's a single plane designed for max power. I have no doubt the GMPP single plane will destory the edelbrock in high rpm power. The new GM LS1 carb intake is designed to support carbs or fuel injection with a TB. Most cars will need more than stock hood clearance.
Old 11-15-2003, 05:40 PM
Technoman64's Avatar
What are they doing for an Ignition System?
Old 11-15-2003, 06:23 PM
strife's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
Old 11-15-2003, 07:48 PM
The GMPP intake can use a crank trigger. An adapter set up that will allow a factory gear driven distruber is also coming soon. It's very trick. It also has a superior runner layout and will be lighter.
I think Edelbrock goes with a belt driven distruber or possiblely a crank trigger.
Old 11-16-2003, 12:22 AM
LS1Tech Co-Founder
Nine Ball's Avatar
LOL, I flew to Vegas and snapped all those pretty photos from SEMA and you didn't check them out?
Tony
Old 11-16-2003, 02:45 AM
Nice4thgenZ's Avatar
THANKS!!! this is what i have been lookin for
Old 11-16-2003, 03:08 AM
68LSS1's Avatar
This manifold includes a unique electronic Timing Control Module made by MSD® which works with OE sensors to fire the “distributorless” ignition system and offers a choice of three timing curves. We have also included a special throttle and trans bracket that works with 700R-4 and Turbo 350 transmissions making the LS1 engine an easy retro-fit into any muscle car, street rod or marine application."
A little info I came across.
Old 11-16-2003, 10:10 AM
CHRISPY's Avatar
It's awesome
Now you can swap a 427 iron block LS1 into a AC Cobra replicar at a fraction of the cost
hmmm 520RWHP and 2000 pounds raceweight
Old 12-09-2003, 12:58 PM
strife's Avatar
Old 12-09-2003, 01:09 PM
Super Moderator
Reckless's Avatar
I think a 3rg Gen Camaro or Firebird with an iron block stroker and carb setup and a nitrous plate system
Strife....is that the "down under" version?
Old 12-09-2003, 01:33 PM
strife's Avatar
no thats supposed to be the gmpp version
Old 12-09-2003, 01:39 PM
JTM
JTM's Avatar
Pretty cool, considering you can pick up a complete LS1 motor for pretty cheap vs. building a regular sbc.
Old 12-09-2003, 01:54 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
I'd say that intake and one of the TB's that bolt to a Holley style manifold will move a ton of air...
Old 12-09-2003, 02:25 PM
Heretic's Avatar
I wonder what the chances are of seeing LSx engines being used in pro racing like NASCAR? Those intakes could be a first step.
If that happens the aftermarket for LSx engines will go nuts.
Old 12-09-2003, 06:08 PM
Nasty N8's Avatar
They already use the LS* motor in nascar in the trans am cars and some of the restricted racing. That is where all of this is coming from. They also have a front mount distributer fuel pump drive.
Nate
Old 12-09-2003, 08:56 PM
Originally Posted by strife
88958675
Awww yes the GMPP single place is finally out in public!
This is the intake I mentioned several months ago. There is also a new control system for it where one can plug in and use the stock crank sensor. That package has a four coil ignition system like the Electromotive set up does.
Front mount distributer, fuel pump & water pump.
Old 12-09-2003, 10:58 PM
MOTRUBL's Avatar
I'd have to agree with Heretic. It'd be fun/interesting to put one of those 4-bbl throttle bodies on it with some fuel injector bungs, fuel rails and what-not to make a different intake set-up. Humm... could this work???
Old 12-10-2003, 02:13 AM
strife's Avatar
like this ?
