Can I make 550+hp with ls6 intake (415ci na)??/Big hp with ls6 intakes come in please
Old 07-12-2009, 05:43 PM
awd2rwd's Avatar
Default Can I make 550+hp with ls6 intake (415ci na)??/Big hp with ls6 intakes come in please
Here are the specs on the motor, just looking for input and maybe other peoples experiences. I really just want to know how much the ls6 intake is going to hurt my numbers! This motor was built for nitrous, the car is already set up for a wet shot from the previous motor.
Short Block (Built by STK Performance)
LQ4 6.0L iron block bored and honed to 4.065
Custom Diamond Flat top pistons -5.5cc/ Total Seal AP rings/Trends 2.200 wrist pin
Eagle 6.125 rods w/ARP 2000 rod bolts
Eagle 4.00" stroke crankshaft
Clevite rod and main bearings
ARP Main Studs/Side Bolts Kit
ARP Head Stud Kit
Fel-Pro MLS 4.100 bore .053”thick
Meziere Electric Water Pump and Motorad thermostat
Ported LS6 oil pump
Valvetrain
Comp Cams Hi-Tech Roller Adjustable Timing Sprocket
LS2 Timing chain
Comp XE R lobes, 244/248 .612/.615 112+2 cam
Comp cam 4.125 hardened pushrods
Comp lifters w/GM Lifter Trays
Heads
All-Pro Cylinder Heads (Ported by Folks Machine) 345cfm @ .600
Ferrea 2.08 Intake, 1.60 Exhaust Valves
Comp Cam Dual Valve Springs/Ti Retainers
Harland Sharp 1.7 Roller Rockers
Exhaust
Breathless Performance Step Headers 1 3/4-1 7/8
SLP Loudmouth exhaust
Induction
Port Matched Ls6 intake manifold
Hand ported Breathless Performance TB
Return style fuel system
Manual fuel pressure regulator
DIY dual walbro fuel pumps
Delphi 42lb injectors
Breathless Performance Vortex Intake system
Compression is right at 12.8:1-13:1
Let me know what you think...thanks
Old 07-13-2009, 04:11 AM
venom ws7's Avatar
Its very possible but change the 1.3/4 headers also since why the small cam for the setup??
What fuel areyou planning to run??
Good luck man but a ported 92mm Fast Intake and 92mm TB Will really wake the car up.
Old 07-13-2009, 08:46 AM
awd2rwd's Avatar
This will most likely be a race gas motor as the compression is too high for 91 but ill leave that up to the tuner...i feel like that is a decent size cam....just wondering how much the fast will "wake the car up" as opposed to an ls6
thanks
Old 07-13-2009, 09:41 AM
PREDATOR-Z's Avatar
You could get the LS6 modified to 90mm by TPIS cheaper than FAST and almost same returns.
You'll need a 90mm TB
Your cam is a bit small for your power goals, I would gather all the parts and get a cam custom speced for your application.
