A very serious (yet embarrasing question) about stroked motors
Ok, a little back story :: About 8 years ago, (i was 13) when I first got into American Muscle, I would always think that a V8 with an aggressive exhaust note was stoked.....fast forward to now, I know that its actually more directly related to the camshaft. So here's my question, can a .....383 LS1 be as quiet on the exhaust as your typical 346 with stock exhaust and aftermarket catback? Like...a stealth stroker (minus valve train noise) I know a few of you may laugh, I'm still wet behind the ears
The throw on the crank is extended in a stroked motor. But the reason most sound lopey is because the builder would throw in a cam. Went through the hassle to stroke, why not heads n a cam? But you can make a Stroked motor sound fairly stock. Close to a non stroker with rockers.
I have a few customers running our LS2 CheaTR cam in their 383's. They drive and idle like stock and make high 400's to the wheels with AFR or other quality cylinder heads.
Thanks,
Shane
Thanks,
Shane
First off a "Stroker" has jack to do with the cam. You "stroke" a motor by lengthening the stroke of the pistons thus giving more cubic inches to the motor without opening up the bore. Cubic inches of a motor is measure in bore and stroke. To get an engine to have a choppy idle will require a cam but that has nothing to do with being a stroker.
I think its fair to say both is true. An aggressive exhaust note has mostly to do with exhaust/cam. But a larger displacement motor (given everything else is equal) is more likely to sound aggressive.
