How can i tell if i am burning oil?
Old 11-17-2003, 12:23 PM
cb
cb's Avatar
Default How can i tell if i am burning oil?
hey i have a 98 ta with 135k miles and i think that i am burning oil can yall tell me how i can check this?
Old 11-17-2003, 12:27 PM
Patman's Avatar
Check your oil level 5min after a hot shutdown, top up the oil so that the level is on the full line of the dipstick. Check it again after a week or two and if the level is down, you're losing oil, if it's not, then you're ok.
Just be sure to always check the oil on level ground, and be consistent in how you check it. If you check the oil cold on a cold morning, you'd get a different level reading than you would on a hot engine.
