Main bearing question
So... Long story short my trans had appearantly been pushing forward on my crank and woredown the thrust bearing. Would it be ok to replace just that one main bearing with a new one and leave the others alone? The engine only has 12k miles on a fresh rebuild. Thoughts?
if the thrust bearing is shot, the crank is probably shot as well. check both thrust surfaces on the crankshaft, i garuntee the rear most thrust surface looks like a record. it should be smooth. i have 2 LS1's like this and am currently on the search for a soultion...
What were they used with? Autos or manual trans and if auto was it modded? I'm interested in this too.
