Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
Old 07-20-2009, 11:40 AM
Jon@Texas-Speed's Avatar
Default Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
Here's a engine dyno data sheet for you guys to look over. This is where we compared & built baseline data of 224 duration camshafts so we can check advance for best average power & build a nice baseline for our newest LS camshaft.
This comparison shows the following camshafts on the same engine same mods
Thunder 224/224 114 Camshaft
TSP 224R 114 Camshaft
TSP 224R 112 Camshaft
Baseline Stock LS1 Camshaft
From testing we did with these camshafts at different advance points we were able to maximize average power across the board for guys looking for nice hp gains across the board.
After creating these baselines we tested lots of new camshaft combos & settled on the all new TSP 224/227 camshaft using all new custom Texas Speed lobes. The new TSP camshaft is a 224/227 .615"/605 112. This camshaft helps to maximize power potential using 224 intake duration. Also included is the new lobes on a sinlgle pattern 224/224 setup using the new TSP .615" lift lobe.
The new 224/227 camshaft is now available for shipping & works great with the PAC Single Springs!!!
Old 07-20-2009, 12:09 PM
Red99TA's Avatar
Cool comparison - what are the other mods (headers, intake, etc.)?
Old 07-20-2009, 01:07 PM
99Ls1fever's Avatar
Cool Comparison!!! Can you go through on each cam and post up the hp and trq numbers. on my notebook it is hard to see them. Thanks
Old 07-20-2009, 01:18 PM
brian_rs/ss's Avatar
ok so im seeing that the 224 cams really make good top end power. the stocker looks to fall off around 4500. this is good stuff Jon!!
p.s. wishin i had bought the new 224/227
Old 07-20-2009, 02:52 PM
TooLateVTEC's Avatar
Great comparisions guys, so how much advance did the cams like?
Old 07-20-2009, 03:01 PM
Tough Mudder
Hilton's Avatar
I love side by side comparisons like this. Can we expect more in the future?
Just curious: Do you have a two piece timing cover, or are you having to pull the crank pulley each time?
Old 07-20-2009, 05:04 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Definitely keep an eye out in the future! There's much more to come including more testing of some of our competitor's products!
We use a QTP 2 piece cover to make the cam swaps fairly quick and painless
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-20-2009, 07:56 PM
airforcemanss's Avatar
wow... talk about seperating yourself from the rest. thanks for putting in the effort in putting the best out
could you tell us what kind of intake and heads?
Old 07-20-2009, 08:37 PM
dug
dug's Avatar
yeah, what are the ICL of each cams?
Old 07-20-2009, 10:03 PM
VaderZ's Avatar
What would the numbers be at the wheels on an a4 with The new TSP camshaft 224/227 using the same mods are your engine?
Old 07-20-2009, 10:23 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Could you post those as numbers. I am mostly color blind and it is impossible for me to comprehend those graphs.
It would also be more interesting and scientific if you posted the complete installed specs of the cams. One may be on a certain icl while the other was installed at another. That could result in the power variances.
Old 07-21-2009, 10:44 AM
Originally Posted by airforcemanss
wow... talk about separating yourself from the rest. thanks for putting in the effort in putting the best out
It's running a stock LS6 intake manifold and completely stock 853 casting heads on all these runs.
Sorry, we are not giving the complete spec of each camshaft such as the ICL out so that our competitors can use the info to streamline and improve their camshaft line-ups. This engine dyno is an investment to help improve our business and to help get the best out there for our customers. Some shops grind a camshaft blindly, and it dyno's nice in one car, and it becomes their best seller and it gets pushed on all their customers whether it's the best for their combo or not. All the while the customer doesn't get the best they could have because not all shops spend the money to do this kind of in-depth R&D. Hope you all understand. I can tell you that ICL/ECL does make a healthy difference on power production and powerband though (all the VE's play their part), and we're glad to have this tool to help us offer the best to our customers!
__________________
Old 07-21-2009, 10:52 AM
This one made 473.2hp/429.1ftlbs at peak with the stock LS6 intake, stock 853 heads, and stock balancer. If you guess at 20% drivetrain loss (depends on convertor and all) you'd be looking at 378hp/343ftlbs at the tire.
__________________
Old 07-21-2009, 10:54 AM
RsSean's Avatar
I take it from those numbers that the dyno was done on a engine dyno and not on a chassis dyno.
For a second there I was about to poop my pants when I saw those numbers. Then I did drivetrain loss and it is about right.
Nice report though.
Old 07-21-2009, 06:19 PM
Felix C's Avatar
it would be nice to compare to this cam as well
http://www.compcams.com/Community/Ar...ID=-1044516358
Old 07-21-2009, 06:51 PM
Arc00TA's Avatar
I really like my TSP 224r/114 cam, made excellent power for a small cam on stock heads and it drives pretty close to stock. I'm wondering how good it will be as a blower cam when I build my rear mount setup
Old 07-21-2009, 07:00 PM
dug
dug's Avatar
not to be a dick, but not knowing the icl, the dynos dont really show anything usefull.
Its just an infomerical for TSP
Old 07-22-2009, 09:34 AM
Dug: We did give the ICL's in the 220 cam thread. You have to understand we're not doing this to give the knowledge away to our competitors. This is for us to improve our camshaft selection for our customers, so they know they're getting the best available.
__________________
Old 07-22-2009, 06:19 PM
just got my car back from getting the 224r install and tune. IIRC it made 374rwhp. and about the same amount of tq. but the real juicy thing is the power and torque curves them selves. i will have a pic of the dyno sheet as soon as i find my camera.
Old 07-22-2009, 06:37 PM
mods at time of dyno:
slp lid/filter/bellow (stock LS1 intake/tb)
pacestter ceramic lt's
TSP o/r 3" TD'S with dynomax bullets
224r 114 lsa
patriot gold dual valve springs
comp magnum 5/16 x 7.400 pushrods
n-motion LS2 timing set
372.33 rwhp 369.86 lb/ft
Quick Reply: Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
