Think my motor is F**KED!?!
Restricted User
Well today after i changed my oil I went from mobile1 10/30 synthetic to napa 15/50 synthetic I went out and took the car for a drive.
I did a few WOT run and on the 3rd WOT it just started blowing smoke! I pull over and the dipstick is blown out and oil is everywhere!!!!!!! oil psi went almost maxed out...
Well i pull over and it goes puff-puff-puff-puff smoke out of the oil cap and dipstick tube. My boost guage still shows 10 vaccum just like befor at idle.
I am running 6 psi.... mods in sig.
What do you think it is? Piston or valve or something else?
Bad thing is im so broke its not funny and im out of a job in a month and a half! I just wanna
thanks,
Blaine
thanks,
Blaine
i think you fried some rings...no joke last week i changed my oil to and than white smoke every where pulled the oil cap same thing pulled my plugs found #7 just as black as can be did a leakage test and #7 failed and air was rushing out the oil cap so your story sounds the same as mine...minus the boost part im not that cool...yetlol hope it help sry to hear tho
Restricted User
will post what i pfind in a minute....
Restricted User
when the motor oil gets hot oil pressure would drop to 30 at idle wanted it a little higher....
I only pulled 1,3,5,7.... none of them are black though 7 is the darkest but not black.... gonna have to do a compression test on all the cylinders tommarow.
plugs are in this order 1 3 5 7
same order as above 1 3 5 7
Restricted User
ok well got to looking at my boost guage and i thought i had the same amount of vaccume (8) as befor but actually i have (10) vaccum now!
How is this possible wouldnt i have lost vaccum???????
When you raise that pressure all the pressure is on the journals and bearings specifically and it has no where to go. That's why some H/C packages have a catch can because even though the right oil is being used when you go to either a ported LS6 oil pump or a lets say a Melling they both are either a High output (LS6) or a High Pressure High Output more along the lines of Melling and a lot of pressure builds in the heads. The catch can helps relive that pressure.
When you don't have that device then the pressure goes out the path of least resistance hence your dip stick/seals and any weak area that is found in your block. Where ever that fault lies is where the oil will travel.
Restricted User
Oil weights are set to flow through the different tolerances in oil journals/bearings at different engine temperatures. If you go out of these oil specs is because you either have done an engine build or a high millage engine, with time these tolerances are no longer as tight(old engines low oil pressure). That flow of oil creates the pressure needed to to make sure that all the bearings have the right separation between surfaces and the ease of flow through journals to reach the bearings and such.
just dont understand why i have horrible blowbye now but better idle vaccum? lol
If i put 10-30 back in do you think it would help out the smoking/blowbye issue? or am i just fu*ked?
I think you'rethinking about the oil weights all wrong. 15-50 is much thicker so therefore it's harder for it to flow through oil passages. This will cause a higher oil pressure but can still mean that you're actually flowing less oil. It's possible that you actually starved your engine of oil even though it's showing higher oil pressure.
so your saying im a dumbass for putting to heavy of weight oil in my motor and i fucked it up!
If you have blowbye that means your rings are fucked, remember they are made to expand as the engine gets hotter riding on a thin cover film oil on the cylinder wall creating that vacume and keeping the piston off the cylinder wall. What has happened probably is that as the ring is getting hotter its expanding remember the tolerances of the rings are about the tightest of all. If there where issues with the rings it was either going to take time, or something going horribly wrong. You just speeded the process.
If you keep trying to make it work your piston is going want to weld itself to the cylinder wall, this I know about remebert that mustang i told u about...well yeah.
Once that cycle is broken then guess what you have issues. On one side the pressure is building to the point it will explode and on the other there is no oil. The pressure is going to release one way or the other and when you have a catastrophic failure that pressure cant release fast enough. It will blow out one way or another.
