push rod length???
Old 11-17-2003, 08:34 PM
sleepersilverado's Avatar
Default push rod length???
ok i have a 226/226 .591/.591 cam in my truck. i am changing it out to a
228/224 .577/.571-114. i would like to know if the comp hardened push rods i have in the truck now will work for the new cam. i am at school and cant remember the length of them at the moment.
would this work or do i need to check the length of the ones i have?
isnt there some way to calculate the push rod lenght?? any help would be appreciated.
Sorry for being a little vague
Ryan
Old 11-17-2003, 08:38 PM
jrp
SN95 Director
jrp's Avatar
pushrod length is effected by heads not cams. stock lenth is 7.400. if you had milled heads then you would go with 7.350 or so.
Old 11-17-2003, 10:09 PM
yea my mind has been a little foggy lately. but thanks. i never even thought about needing diffrent ones but then i had a brain fart. but you know it is better to be safe than sorry.i should be good to go
Old 11-17-2003, 11:06 PM
Tally TransAm's Avatar
as long as the cams base circles are the same youll be fine
