lq4 6.0 +TSP Tsunami cam + 243
Old 07-23-2009, 07:39 PM
TX RED's Avatar
Default lq4 6.0 +TSP Tsunami cam + 243
ok so one of my ls7 lifters went out took my block and cam with it lol.
So new build.... Here goes nothing
stock long block lq4.... well arp rod-bolts,
fully ported 243 or 317 milled .030
TSP Tsunami cam ( Texas Speed Tsunami 235/240, .654"/.609", 111 LSA )
pushrods...? need to buy a comp length checker
ls2 lifter trays
for now ported ls6 intake
42lb lucas
I might need to sell my long tubes for some 1 7/8
is there any thing better than a ls6 ported form TSP oil pump
what do you guys think? am looking for 450 rwhp mabey 470 after 90/90 swap. should I even think about ls7 lifters or just go with comp
Old 07-23-2009, 09:33 PM
TX RED's Avatar
anybody
Old 07-23-2009, 09:36 PM
ricknbird350's Avatar
thats the same setup im trying to build. im doin the lq4 with the patriot stg 3 243 heads. im aiming for 450rwhp to. keep us updated on your build im anxious to see what you put down
Old 07-23-2009, 09:37 PM
i was gonna go with the ms4 cam practically same cam
Old 07-23-2009, 10:49 PM
TX RED's Avatar
Any ptv problems
Old 07-24-2009, 12:15 PM
TX RED's Avatar
any body running this steup
Old 07-24-2009, 01:27 PM
NemeSS's Avatar
Originally Posted by TX RED
Any ptv problems
just pretend u will always have ptv and just go ahead machine in relieves or buy piston with relieves. and correct pushrod length and degreed cam with adj. timang chain, is the only correct way to install valvetrain.
problem solved.
milled 243 will equal more scr, which equal more dcr.
Old 07-24-2009, 02:06 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If you stick with the stock LQ4 short-block, try and go with the 243's. That smaller chamber will help get you some compression as compared to the 317's and they perform alot better. Also, if you're going with larger than stock valves avoid milling them that far for sure (piston to valve clearance would be a major concern)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-24-2009, 05:33 PM
TX RED's Avatar
problem solved.
I will be sure chk all that stuff.
Old 07-29-2009, 10:56 PM
i figured with the lq4 having dished pistons it would be less likely to have pvc issues with a bigger cam. how much to have them machined compared to buying new ones that already have reliefs in them?
Old 07-30-2009, 07:58 AM
Tough Mudder
Hilton's Avatar
I've done something similar, and hope to soon be able to crank it.
LQ4
TrickFlow 215cnc
custom cam 231/239 LSL lobes
LS6 intake
Old 07-30-2009, 10:22 AM
98blueSScamaro's Avatar
I say run ls3 heads made power with the stock ls3 intake. well worth the money and should put you really close to 500rwhp
Old 07-30-2009, 01:35 PM
TX RED's Avatar
ls3 heads have been selling cheap too. Still not sure on everything...you think 500rwhp
Old 07-30-2009, 01:40 PM
look up I8AFORD stock ls3 heads on a 415 iron block stock intake G6x3 i think for a cam his car moves out for sure my next car will have ls3 heads and intake for sure
Old 07-30-2009, 01:47 PM
TX RED's Avatar
damn just looked him up. car moves
Old 07-30-2009, 01:59 PM
I ran with him at the track and the car get down and the can is not lopey at all i mean 500+ with stock ls3 heads and intake thats the way to go hands down
Old 07-31-2009, 12:41 PM
TX RED's Avatar
what more do I need to run ls3 top end ?
Old 07-31-2009, 01:18 PM
mred's Avatar
whats the advantage over the 243 heads versus the 317?
i have a Lq4 in the works but going carbed and gotta mill the heads on the 317s
thanks
Ed
Old 07-31-2009, 02:25 PM
NemeSS's Avatar
thanks
Ed
pretty much same intake and exhaust port design, but 317=71cc chamber
243=65cc chamber, the 243 will yield higher scr everything being equal
Old 07-31-2009, 06:40 PM
mred's Avatar
cool thanks
Quick Reply: lq4 6.0 +TSP Tsunami cam + 243
