Fixing to pull the motor in my car, please double check my set-up..
Ok guys next week i hope to pull the motor out of my 01 Z28 for a rebuild and heads/cam/and intake swap. Would you guys please double check my set-up and see if im missing any parts. I really appreciate any help!
Fast 92mm Intake (with new gaskets and new bolts)
Nick williams 92mm Throttle body
Fast 32lb Injectors
Re-using stock fuel rails
Had an extra set of 241 heads ported and vavle job done and has matching dual vavle springs for the cam
*Pushrods ill order after the motor is out (check length)
LS7 Lifters
*LS2 lifters trays
Custom grind cam specd by Patrick G
Ported and shimmed LS6 oil pump
LS2 Timing chain, reusing stock sprokets
Ill be rebuilding the stock bottom end. Ordering my rings and bearings after i pull the motor out and tear it down.
As for bolts ill be using new GM head and rod bolts.
I have all new gaskets for the whole motor.
And i have a 3600Yank stall and trans cooler on the way.
Anyone think of anything else i need?
Fast 32lb Injectors
LS7 Lifters
*LS2 lifters trays
Last edited by Zach79Z; 07-23-2009 at 08:35 PM. Reason: Forgot to add timing chain and oil pump
Ok i could be wrong but i thought pulleys didnt add much power on ls1's? Like i said im prolly wrong so please dont flame me lol. I got new wires and plugs for it and guna keep the stock maf for now. Thanks
No flaming here, but lookin at your list of goodies, why not...granted they don't add 20hp, but they do help....just look around, alot of people are running aftermarket pullies, especially when they do a cam swap.
