6.0 help
Old 11-18-2003, 02:22 PM
Big_Steve's Avatar
Default 6.0 help
Has anyone around this board built a 6.0 motor. I am looking for a little help as far as what I should be looking for. Crank wise did you stay stock or go to an aftermarket crank. What heads did you use? etc.
Old 11-18-2003, 03:10 PM
Super Moderator
Reckless's Avatar
Most details in my sig. Stock 5.7L crankand Abs Speed 5.3L heads.
Old 11-18-2003, 04:52 PM
Chicago Crew UnderBoss's Avatar
I had a 427 iron motor with 4.060 bore and 4.125 Callies (piece of junk crank)! The stroke was too much for that bore on the 6 liter motor and geometry of motor was way off causing MAJOR PROBLEMS! Words of wisdom=stick with a LUNATI 4.00 crank and no bigger and go with 4.030 overbore for 409 classic Chevy cubes and lots of strength and room for rebuilds in the cylinder walls.
Would be a solid stout performer matched with aggressvice cam and ported stage III LS6 heads and all necessary bolt ons would give you a 10 sec. something street car. Throw on the gas or other F/I and you have yourself a 9 sec. something potential street/drag machine.
GOOD LUCK!
Old 11-18-2003, 05:03 PM
Scalpel's Avatar
MTI 427 hit on the head.
Old 11-18-2003, 05:07 PM
Scalpel's Avatar
BTW, MTI 427, are any of the LS1 motors able to use the 4.125" stroke?
Old 11-18-2003, 08:00 PM
Levi,
I am certainly no mechanic and i know many LS1 people are runnnig around with this big crank in resleeved alum. LS1 motors and in my opinion, all stroker motors seem to be using too much oil and i wonder if the big crank is part of the reason.
I was also told by a top tuner that the overbored iron motors do have a different configuration/geomerty vs. an alum. engine. Also, many tuners over the last year or two told me they would never go with more than a 4.00 stroke in a LS1 motor although many do and seem to be happy so far.
Hope that helps a little.
Old 11-18-2003, 11:26 PM
strokedls1's Avatar
I have a 4.075 offset ground lunati crank. Can't be happier with it. No excessive oil burning, and good oil pressure. All the tolerances are to spec, and 0 balanced the rotating assembly. The motor kicks some serious ***. I am using a set of stage 2.5 5.3L. I would look into some ls6 or 6.0L heads if you are going with a bigger cube motor.
Old 11-19-2003, 01:20 AM
Big_Steve's Avatar
Great that is exactly what I was looking for. BTW I know you can't tell me exactly but what do you think a 409 with the SLP head and cam package, LS6 manifold, and long tubes would push HP and Torque wise. I am looking to throw this motor in a 1969 Camaro and I need it to be streetable. You think it will be reliable or need a rebuild every 70,000 miles. Granted this wont be an everyday car but that doesn't mean I want to be fixing something all the time. Thanks again for all the great info.
Old 11-19-2003, 02:02 AM
Scott Turvey's Avatar
Given what most people would do with a motor this size (run the #$% out of it occasionally), I don't think a rebuild every 70k is unreasonable.
With regard to these large stroke LS1's, anytime you go over the 4" stroke, the rod angle is getting out-of-hand. For instance, with a 4.125 stroke, you're going to get a 19+ rod angle with any rod 6" over over. This ain't gonna work for a motor expected to lead a long life.
So, stay with a 4" or less stroke and you should be in good shape, assuming rational treatment of the motor...
