Spun Rod Bearing
Old 07-27-2009, 09:45 PM
BlackTA96's Avatar
Default Spun Rod Bearing
I've got a 98 ls1 with a spun rod bearing.
I've also got a stock lq4 crank and rods.
Would I be able to but the lq4 crank and rod into my ls1 without any issues?
Old 07-28-2009, 09:09 PM
MelScrilla's Avatar
I think it should work because the only difference between the rotating assemblies for the 2 motors was the bore is larger on the 6.0
Old 07-29-2009, 02:08 AM
98RedBird's Avatar
Originally Posted by MelScrilla
the above account for BS
WTF dude?
To the OP, IIRC it will work, but you'll want to double check that. Just make sure that you have the crank polished and all of the clearances checked out.
Old 08-11-2009, 01:59 PM
BlackTA96's Avatar
anyone know for sure?
Old 08-11-2009, 02:40 PM
evangto87's Avatar
more then likely the crank is balanced for 4.000 bore pistons. Everything would fit but i would bring the assembly to the machine shop to have them rebalance it.
Old 08-11-2009, 04:27 PM
BlackTA96's Avatar
Thats the main thing I was worried about.
Old 08-12-2009, 01:31 PM
MelScrilla's Avatar
Originally Posted by 98RedBird
WTF dude?
at the time i posted that there was a spammer post above my post that has since been deleted.
No disrespect meant to the OP.
