XER lobe vs XE lobe etc
Is there going to be much of a power difference between these two setups ??
Stealth II 224 220 581 581 116 XER
or this custom Grind comp cam with 1.75 rockers on regular lobes
224 220 564 564 116 + 1.75 magnum rockers = 224 220 580 580 ??
The 1.75 should make the custom cam perform similar to the MTI cam. However, if you plan on running the 1.75 w/ the stealth cam it will make more power but lift will bw higher than .581. Didn't you want to keep the lift down or is that no longer a concern?
