heads and pushrods help please!
Old 07-30-2009, 11:07 AM
6th gear's Avatar
Default heads and pushrods help please!
I am about to install a set of 2.02 5.3 heads on my goat.I was wondering since the heads have been milled .030 would i have to change pushrods?Thank you for you help and input.
Old 07-30-2009, 11:20 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Yes, between the milling, different camshafts, variances in block deck height straight from GM, etc you'd definitely be serving yourself well to measure and get the correct length. It'll save you alot of time and frustration in the future to do it right the first time!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-30-2009, 11:31 AM
6th gear's Avatar
How do i measure this?Or if somebody knows what size rod please chim in.Thank you!
