Spec Me out a torquey cam pls
Can some spec out the Torquiest cam for a set of PRC LS6 stg 2.5 cnc ported heads? With all the power from Low-Mid range RPM pls, thnx
LS1Tech Premium Sponsor
What short-block and bolt-on mods do you have? That'll help us recommend a camshaft that fits your combo best!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Ok the setup is 346 ls1, LS6 intake for now, PRC LS6 stg 2.5 cnc ported heads, pacesetter longtubes, ORY with cutouts, magnaflow exhaust, Strange 12 bolt rearend, 4.11s maybe 4.33s later.
So now whats the TORQUIEST CAM for this setup?? Whoever, Comp cams, Texas speed, Thunder racing, makes the torquest camshaft I will buy, cant wait anymore, Thnx
231/227 .617/.614 110-1 lsa
That will give you what you want.
Strong trq 3000 rpm > peak
Peak ~6200 rpm, shifts ~6600
Power range 2200>6600+
9* overlap (nice rapid popcorn lope)
It will sound very similar to this:First with cutout closed then open
http://www.youtube.com/watch?v=LpU-CC5OOM0
