Trickflow as cast VS ported flow #s?
Does anyone know what the trickflow as cast heads flow? I see they had a flow chart for the ported ones, but nothing for the as cast heads. I'm just wondering if they would even be worth buying since theyre $500 more. My tuner just recommends the as cast heads since he makes good power on those.
i dont know the flow numbers but Vengeance and Tick Performance both use the as cast heads in some of their h/c packages so they do make good power, but they usually fall short of the cnc 215's. The upside of the 220's can be ported in the future and they would probably work better than 215's especially on a stroker motor.
Well I'm going to a stroker whenever this motor dies. But I could pick up another set when that happens. He made 445whp through as cast heads with a 228/230 cam with a completly stock LS6 intake and stock TB.
Trick Flow 220cc "As Cast"
Lift Intake Exhaust
0.100 67 47
0.200 133 104
0.300 211 167
0.400 261 202
0.500 292 222
0.600 305 233
Trick Flow 215cc CNC
Lift Intake Exhaust
0.100 66 54
0.200 138 118
0.300 218 187
0.400 272 231
0.500 308 252
0.600 324 262
Lift Intake Exhaust
0.100 67 47
0.200 133 104
0.300 211 167
0.400 261 202
0.500 292 222
0.600 305 233
Lift Intake Exhaust
0.100 66 54
0.200 138 118
0.300 218 187
0.400 272 231
0.500 308 252
0.600 324 262
does anyone know if trickflow has a cnc program for the as cast heads if you ever wanted to open them up. Or are there any other companies such as TEA that have a cnc program for the 220's?
in the for sale section someone has some 220's that are ported but by hand, i guess that works ok but if the workmanship sucks, so do your heads for the rest of time you have them.
Since i dont know any genius porters in my area, and the only other person i really know of is Tony Mamo (I dont know if he would do TFS since he's AFR). I would rather stick with the R&D companies put into a good CNC program.
