Intake centerline # for a ms3 with a 113 lsa
Old 08-06-2009, 11:36 PM
Fast Bird's Avatar
Default Intake centerline # for a ms3 with a 113 lsa
Does anyone know the intake centerline number for the ms3 on a 113 lsa, i am trying to degree this thing. the paper i got from texas-speed dosen't have all the info on it. thanks.
Old 08-06-2009, 11:40 PM
LSX Mechanic
Damian's Avatar
Do you know how much advance is ground into it?
113 LSA + 4 degrees = 109 ICL
113 LSA + 2 degrees = 111 ICL
LSX Mechanic
Damian's Avatar
Old 08-07-2009, 12:08 AM
LSX Mechanic
Damian's Avatar
Hey thats neat. I double posted.
Damian FTMFW
Old 08-07-2009, 02:21 AM
Fast Bird's Avatar
yes i do its +3 so i guess that would be 110 ICL .
Old 08-07-2009, 07:00 AM
Fast Bird's Avatar
I am coming up with a 114.5 and i should be getting a 110, the timing set i have didnt come with the bushings, it has timing marks and slots on the crank gear, do i need to move the gear to the -4 slot to corect this?
Old 08-07-2009, 06:01 PM
vsocks1's Avatar
What timing set? You need an adjustable timing set.
Crank degrees and cam degrees are two different things!
Old 08-08-2009, 08:57 AM
Fast Bird's Avatar
I have an adjustable double roller, it only has the slots on the crank sprocket, i put it on +4 and tried it again and came up with 110.5 is this corect or not.
Old 08-08-2009, 09:01 AM
Fast Bird's Avatar
Its the JP Performance set.
Old 08-10-2009, 07:07 PM
JPH
JPH's Avatar
Go by the IVO, your centerlineswill probably be off anyways.
Quick Reply: Intake centerline # for a ms3 with a 113 lsa
