some one help me im at my wits end
Old 08-09-2009, 05:20 AM
f-bodyguy's Avatar
Default some one help me im at my wits end
ok heres the deal..i have an 02 t/a...i built an iron block at the begining of the year...ran fine...put in the cam,cam sensor went...still drove fine/started bad idled rough..no tach...well yesterday it started running like ****..anyload it would try to die..couldnt really get it to idle out right...threw p0106(map/ something else. a friend had both sensors off his motor and gave them to me i pulled the intake an replaced the sensors..started right up...then died..hard to start again and wouldnt really run so i made it out of the driveway sputtering,,i hit it going up the street and it smothed out a bit but still reall hesitant..tach is now a bit intermitten and i dont know what to do ive had it...cant affford to take it anywhere..and its not ecause its untuned because its been that way for ab out a month or a little more..anything people???
Old 08-09-2009, 08:28 AM
adam1803's Avatar
Check your engine grounds, i had a similar issue after my head swap and that was the problem.
