Unknown connector, tach not working?
Old 08-09-2009, 12:21 PM
Sketch_hs's Avatar
Default Unknown connector, tach not working?
Might be related.
Just dropped a new crate ls1 in a 99 camaro, not sure where this connector goes?
it comes from the back of the engine wiring harness. I couldn't figure out where it plugs into?
Also the tach isn't working, any ideas or maybe this is related?
thanks in advance... i'm kinda new to domestic engines.
Old 08-09-2009, 12:41 PM
Sketch_hs's Avatar
The map is plugged in, this looks almost the same as that connector. Engine runs and idles good, maybe a little long to start.
colors are:
brown with white stripe
pink with black stripe
red
Old 08-09-2009, 12:47 PM
99RTA's Avatar
Might be for the cam sensor, its back there too. Explains why the tach doesn't work too. It uses the cam sensor.
Old 08-09-2009, 12:54 PM
Sketch_hs's Avatar
Where does the cam sensor plug in?
Old 08-09-2009, 01:05 PM
Sketch_hs's Avatar
found it, back of the intake manifold. Ouch that was hard to plug in without removing IM
thanks guys
