Most heads/cam power with stock manifolds/cats?
I'm wondering what the high side is for heads/cam/bolt ons and stock exhaust manifolds (or true shorty headers), with the stock cats/ypipe system? Anyone break 400rwhp?
there was a guy in houston (screen name AAron) dynoed 400 rwhp with st2 gtp heads and the original hammar cam 222/222 .566/.566 112 w/ stock manifolds and ypipe through loudmouth exhaust. it was a 2001 camaro manual tranny
Only heads and cam car I know that dyno'd with stock manifolds was a 99 T/A it had a 216/220 cam and made ~356rwhp. I think MORE had a few get near 380rwhp a couple of years ago.
I'd like to know the answer to this too. I'm going to be stuck with 00 manifolds on my 3rd Gen for a while.
Porting with a grinder going to help much?
why spend thousands on a H/C package when you can do a nice cam and Longtubes for probably less and be VERY close to the 400 mark....just doesn't make sense to me...explain why u want the stock cats...??Street racing or something????
SN95 Director
If you are going with stock manifolds make sure they are '01+.
I think I remember you bought a vette, if so go with an '02+ Z06 full exhaust (manifolds X & catback) their cats and catback would be your best bet for making good power with a "stock" exhaust system.
Why use stock manifolds:
1) Not that CA emissions have stopped Terry in the past, CA has a reputation of enforcing the visual inspection and long tube headers are illegal for on road use (even if you can pass the sniffer) because you have tampered with emissions control equipment.
2) Headers are noisey compared to stock manifolds.
Like I said on the other forum, I made 393rwhp through stock exhaustmanifolds, stock cats, and stock mufflers.
Mods were Thunder Racing (GTP) heads, TR227/224 cam, ASP pulley, and 2001+ intake manifold.
Reasons not to use headers....they make the car sound like **** (in the engine bay, under the car, etc)...rattling, exhaust pulses seem to be noisey, they aren't legal in CA, they scrape on lowered cars. The stock exhaust setup sounds oh so smooth, OEM, no leaking/rattling/pulsing noises.
It seems that just about every long tube out there either hits the floorboard (and requires a BFH or some heater hose to fix - both a bit ghetto in my opinion) or it scrapes on all but perfect roads. Or it reduces clearance to get to the oil filter and oil drain plug. And all these packaging issues are even worse if you want to add cats on the back of the long tubes.
It all depends on what you want from the car.
You could do a cam only car and get very close to the 400rwhp mark.
You could do heads and cam and get very close to hte 400rwhp mark.
You could do a 383 and get very close to the 400rwhp mark.
But the cam only car would feel very different from the 383 car.
Think huge cam, duals that dump before the axles, and 400rwhp vs. mild cam, ported heads, more cubes, and an exhaust all the way out the back through cats and mufflers and 400rwhp.
One is great for a weekend toy, but it might get on your nerves if you drove it every day or took it on a 500 mile trip. The other is a more relaxed grand touring vehicle that can still haul *** if need be, but doesn't sacrifice any of the car's daily drivability and NVH characteristics.
