Ummm? What? LS6 Cam in 2002 Camaro SS?
The LS3 camshaft is typical Gen 3/4 faire--a gun drilled steel billet with roller hydraulic lifters. It's based on the one used in the LS6 which was used in a few 2002 Camaro SSes.
First Paragraph....
Bad information or something I just didn't know??
LSX Mechanic
I've never believe the myth that a few 02's got the LS6 block, until I stumbled on one last year I put heads on. It had an LS6 block, and was an 02 car.
As for the cam, I highly doubt that. That would then require LS6 valve springs due to the higher lift of the LS6 cam.
LS1TECH & Trucks Sponsor
Some got the LS6 block, NONE got an LS6. Rumor that will never die
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
Kleeborp the Moderator™
There's a reason why you aren't finding the information - it is because it never happened. If an '01+ F-body ended up with the LS6 heads and/or cam, it was because the owner put it there, not the factory.
As stated, all '01+ F-bodies got the LS6 intake, and a handful of them got an actual LS6 block, but the block itself contributes nothing to the performance. FWIW, mine came with an LS1 block, built somewhere around October/November of 2001 as a 2002 model.
