Heads/cam help
Old 08-15-2009, 05:37 AM
02blackws679ta's Avatar
Default Heads/cam help
Finally coming back stateside and since my car has been garaged and neglected for almost 4 years I finally want to do a heads/cam swap. I figure it'll be my 'getting-out-of-the-military present' to myself
I've got kooks longtubes/lanes duals and pretty much every other bolt on.
Seems like I've been out of the mod game for so long, so I'm lost
The car made 365ish to the wheels as it sits.
I want it to be completely streetable and not obscenely obnoxious or anything but want decent power. I'm already illegal with the !cats and dumped duals but I've been lucky with that being overlooked for inspections so far.
Old 08-15-2009, 06:08 AM
http://www.byunspeed.com/product_inf...5f96263dc34af1
Would the trick flow kit be mild mannered enough for what I'm looking for?
God I feel like I'm starting all over with my car knowledge :o
Old 08-16-2009, 12:20 AM
bowman2005's Avatar
I have the trickflows and they are pretty beasty...I would say get the stock heads worked and get a nice cam to match.Just look at it like this trickflows are one of the best heads out for these cars so you know what to expect out of them,the cam you get will decide how streetable the car will be.
Old 08-16-2009, 02:59 AM
franksaltz28's Avatar
If your looking for something thats mild and not to much on the pocketbook, look into texas speed prc head cam swaps.
Old 08-16-2009, 05:24 AM
"Beasty" how? Is the car streetable? I would like a little cam lobe and obviously increased power but I don't want some track beast that stutters and stalls all the time.
Old 08-16-2009, 07:35 AM
khaotic's Avatar
Default my 2 cents head/cam
243 casting LS6 head, CNC port and open up to a 2.00"/1.60" Manley stainless steel valve with a three angle performance valve job and, back cut the valves. Resize the guides for the proper clearance and set the installed heights and surface the heads to 62cc so you will have a 11:1 compression with your stock piston and the .045" Cometic head gaskets. If you piston sticks out of the hole .010" like most LS1 engines then this will give you a .035" quench height which will be perfect, and help keep engine knock down in my opinion. The cam Extreme Energy grind from Comp Cams and it has a 230/236 Duration @ .050" and a .600"/.600" lift on a 112 LSA, this cam works great with these heads and I recommend checking the degree point noted on the cam card when installing the cam.
With that combo a 7.400 push rod but always check the geometry, along with your other mods that should make a great streetable ground pounder.
Owner of 3 fbody's and last years IHRA pro outlaw and Ironman qualified this year for world finals. Running 6.84 1/4 mile in our S10
Old 08-16-2009, 08:00 AM
SOMbitch's Avatar
Oversize valves+mill+.045 Cometic is gonna make PTV very tight. IMO your are gonna have to flycut that combo.
IMO as long as budget allows get the TFS 215's and mill for desired compression and drop in a high 220's or low 230's cam. Then top it off with a Fast 90 or 92 preferably ported.....
What is is your budget. That would really help us make suggestions......
Old 08-16-2009, 12:06 PM
TransAmcoupe98's Avatar
Don't port those stock heads. At least get some stock LS6 heads or maybe some ported ones with stock runner size. If you got the cash for some TFS, definitely do that with a mild cam. Something like a TR224 or 224/228 with a 114lsa to keep it a little tamer. You would make awesome power.
Old 08-17-2009, 05:50 AM
Money really isn't an object although I don't want to spend retarded amounts. less than 3 grand.
I want good power but tame street manners.
Old 05-19-2010, 09:16 AM
rich5368's Avatar
For $3k I definately say get you a TSP head and Cam combo. I'm going to go with the PRC stg 2.5 5.3 heads milled for a 62cc chamber and cometic .045 gasket and a cam. I priced the combo out at $2K including the timing chain and a ported LS6 oil pump. I'm going to go with their headers, x-pipe,and true dual setup too. I like their prices, what can I say?
Old 05-19-2010, 05:33 PM
garygnu's Avatar
what heads and intake are on the car now?the TSP combo with bigger injector and a tune will fit your budget.
Old 05-19-2010, 05:37 PM
sidewayz28's Avatar
youre going to get a million different answers/suggestions here.
i suggest a custom cam.
choose which heads u want to go with and get the cam spec'd to work with them instead of mismatching parts.
Old 05-19-2010, 09:30 PM
garygnu's Avatar
check out vengeance racing current head/cam kit in the sponsors sales section.
