saw a 98 trans am for sale
he only wants 3500 for it but here is the catch.. it has 155000 miles and runs ruff i here no bad sounds from the engine as for failer no time soon but has no exhast and idles fine but 1st and 2nd is ruff untill you get to 3rd gear and the car smooths out, trans seems o shift fine.. just wanted to know is it worth buying and putting some money in to to make a nice 7k car after im done????
Make the guy take it to a shop and have it hooked up, see what alls wrong with it and sounds like the forks might be bad in the transmission between gears or could be other things as well, trans could be ab to fall apart for all you know. Tell him if he wants to sell it then take it to a shop and have it tuned or just a regular check up let the guys check the oil, and trans fluid, and run a few tests on it and then you can see just how bad/good it is.
3500 and its drivable but runs rough????is oil pressure good???any smoke????and the tranny shifts fine???if the title is clean and the body is straight id jump on it.....or atleast in my area that would be a good deal...
low oil? id check the oil, it could just be the sensor. if its low on oil, find out when it was last changed and also where/if its leaking. if it doesnt leak, then dont buy it unless you have the money to replace the motor soon b/c the rings could be shot..
Mine is a 98 and HPtuners tuned by TTPerformance and the car runs really nice. No problem whatsoever because its a 98 Matt at TTP awared me of.
I woud buy this and be ready to replace SB with a 408, along with nice heads and boltons!! you could get a 500rwhp monster for 10K LOL, if body and interior is straight...
