LS1 CAMARO engine questions
Hi
I notice u can easily find mustang ud pulleys (3 pulley's) but u can get only 1 pulley for crank in camaro's! why that? is there are brands sell 3 ud pulleys which i dont know??
for example in this MARCH website link, which pulley's fit 98-02 camaro?? long water pump or short water pump?? or there's arent any??
http://www.marchperf.com/csb_pulleys.html
*Engine question:
-as seen in summit catalog, does TRICK FLOW ls2 kit will fit ls1 engine???
-Also does ls2 heads(575hp) and ls7 or after market gm lsx heads(680hp) will fit on ls1 engine??
-Is it possible to put maggie (magnacharger) on camaro engine? and how? which is best, FAST 98mm intake with full bolt-on or Magnacharger with full bolt-on??
-How can i know my car has power steering cooler??
Thanx
*Engine question:
Thanx
Hi
Forget Ford, welcome to Chevy's we do not need other than 25%
Long WP
*Engine question:
Not recommended, the 228/230 LS1 combo is better for 346 cubes.
L92/LS3/LS7 will not fit
LS2 heads will fit
Yes it is possible, but requires a lot of work and some custom parts.
There are 2 different companies offering kits. Search in Forced Induction forum and you'll find both threads.
No doubt adding a SC is better
follow the hoses from your PS pump. If it goes to cooler then yes, if it goes to steering shaft then no.
Thanx
Long WP
*Engine question:
LS2 heads will fit
Thanx
Thanx 4 the info,if u saying that ud pulley not requird then why everyone buying them? and im not new to camaro's so dont need to welcome cauz we having chevy's since 70's
Im sorry i didnt know that making the letters bigger will mean un polity,im raised in good family so i know how to respect people
Thanx agian for the info
That is why we say "Ahlan wa sahlan "
I said 25% underdrive is max we use to keep all electrical systems charging properly. When you underdrive the crank it slows down alternator and power steering functions. Slowing power steering is good, slowing alternator too much can have charging issues.
I know Muscat, I live in Dubai and I have been there a few times. Being an Arab you know that welcoming anyone is respectful and always welcomed.
Dubai is very dream city to live in but 2 times expensive then muscat
Thanx 4 the info and if u need anything from muscat just let me know ok, even OMANI HALLUA
ما في أي مشكلة و أنا موجود اذا احتجت أى معلومات. شو اسمك الكريم؟
مارك
Yes you would only need the crank pulley. I use a March, it is one of the best for harmonic (crank vibration) control.
مارك
