Which pick up tube o-ring for mellings pump,blue or black?
Just like the title says. Im rebuilding my engine. Im re using my melling high volume pump and i took out a black o-ring. My problem is that when i bought the o-ring at the dealer its blue. Is there any real differance. They look about the same. The black one has 10k on it so its aliitle harder.
Thanks
Alex
Thanks
Alex
LS1TECH & Trucks Sponsor
If you used the Melling o-ring it would definitely be black, but a GM replacement that is identical should be blue. Hold them up together and if it looks right, it is right.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
