What size of pushrods for setup?
Old 08-20-2009, 11:04 AM
WS6_ALV's Avatar
Arrow What size of pushrods for setup?
Im getting an ls6 cam installed on my ls1 engine with stock rockers, but Im also getting new ls7 lifters installed. I have done some research regarding the size of pushrods. Some people say the correct size should be 7.425 others say 7.350. Unfortunately I dont have the time to get it measured and then buy the pushrods, since I live in a small town. Any input would be very helpful.
Old 08-20-2009, 11:38 AM
XtraCajunSS's Avatar
This is from a post I made last night. If you are running stock untouched heads and stock gaskets, 7.400" should work fine.
Originally Posted by XtraCajunSS
FWIW, EVERY cam install I have done using the LS7 lifter with a cam with greater than .600" lift (read smaller base circle) AND stock heads w/GM MLS gaskets has taken 7.425" pushrods for ~.050"-.060" preload. We measure lifter preload on each and every cam install we do. I have never had a lifter failure nor do we end up with the dreaded "sewing machine" noise.
Its very simple, If you change ANY of the following:
valve sizes, valve job, head milling, thinner/thicker head gaskets, decked block, cam with an altered base circle, etc... YOU MUST CHECK FOR PROPER PUSHROD LENGTH.
I have helped countless numbers of individuals with this process over the phone, via email, and PM's. I've posted the process on at least 3 occasions.
Here it is again in a nutshell:
1. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
I might not know everything but I will tell you that this method has worked for me year after year cam swap after cam swap. We average 3 cam swaps a week here so you can do the math.
If you are not familiar with the EO/IC method for determining valve events in a 4 stroke engine, its very simple:
For a given cylinder as the Exhaust valve is Opening, the intake lifter will be on the base circle of the cam and lash/preload should be checked for that intake valve.
For a given cylinder as the Intake valve is Closing, the exhaust lifter will be on the base circle of the cam and lash/preload should be checked for that exhaust valve.
THIS METHOD ALWAYS WORKS!!!
I hope this helps someone. I have explained it so many times I think I do it in my sleep!!!
Shane
Old 08-21-2009, 11:00 AM
2001ws6-500hp's Avatar
very usefull, too many "how long should my pushrods be" threads out there
Old 08-21-2009, 12:07 PM
I am not joking or exaggerating when I say I answer this question 5+ times a day.
Shane
Old 08-21-2009, 03:49 PM
is there anyway we can get a do it yourself guide as a sticky on how to check for your own pushrod length?
Old 08-21-2009, 05:08 PM
We can see if the Mods will make it a sticky...
Shane
Old 08-24-2009, 12:31 AM
WS6_ALV's Avatar
thanks for the info guys.
