5.3L 706 Heads, Milling, Port & Polish, Cam & Spray Questions.
Old 08-20-2009, 11:17 AM
MoNoXSizzlE's Avatar
Default 5.3L 706 Heads, Milling, Port & Polish, Cam & Spray Questions.
I recently acquired some 5.3L 706 Heads, the plan is to get them ported and polished. Should I use the 241 valves off my current stock heads or would the stock 706 valves be alright?
Two other things.. How much should I get them milled to? I currently have a Torquer 2 cam and plans to run nitrous, I just want to run a 100 shot for now, but I'm looking at spraying up to 200 in the future. The specs on the Torquer 2 are: 232/234 112 LSA .595/ .598.
Now I currently have the PRC Double Spring and 7.400 Chromoly TSP Pushrods on my 241 heads, can I re-use these springs and pushrods with these new heads with no problem? Springs, pushrods and cam have about 2,500 to 3,000 miles.
Any input would be appreciated. Thanks.
Old 08-20-2009, 11:37 AM
NemeSS's Avatar
should be able to use the existing springs, but have a prof. machine shop inspect them and install them before reinstallation. since the heads are getting machined/ported anyway.
imo not worth spendin $ on 706 just to accomplish the same flow as stock 243 or 799. find a good set of 243/799 upgrade with vj, 2.02 valves upgrade, mill and your springs. spend way less than a p/p order.
imo
Old 08-20-2009, 11:39 AM
imo
Thanks for the feedback, but this deal on these heads were too good to pass up. I got them for real cheap.
Anymore feedback? How much milling?
Old 11-06-2009, 06:55 PM
synisterC5's Avatar
i have a set of these heads on my work bench right now waiting till spring to complete the job. I had the heads cut for the 2.00" valves, when the new seats were cut it automatically leaves you with A THREE ANGLE VJ, it only cost me $80 for the machine work and im cleaning up the port work myself, so these heads are extremely economical!
I have been told that the v2 cam is a tight fit (even without milling) and i couldnt get a very straight answer on weather or not there would be a ptv issue.
however im dying to know how it works out for you
Quick Reply: 5.3L 706 Heads, Milling, Port & Polish, Cam & Spray Questions.
