oil leak after h/c
Old 08-26-2009, 08:30 PM
racerfox's Avatar
Default oil leak after h/c
sup guys i just finsished my tsp trq 3 and prc 215 install and on the test start oil is leaking right above the oil filter is there some trick for droping the pan or a nother way to seal it i have tried tighten the bolts around it and its still leaking any ideas ill post up some vids and pics whens shes done
also i reinstalled my water pump and on start up it broke the shaft and now leaks water so i have to go buy a new one should i upgrade to a higher flow pump and if so what pump would you buy ?
thanks guys i have done nothing but wrench on this thing for 6 days and i want it done
Old 08-26-2009, 09:53 PM
TooLateVTEC's Avatar
I would just buy a stock water pump.
Where is it leaking from? The oil pan gasket?
You didnt remove that metal piece above the filter to put your headers back in and forgot to put it back on did you?
Old 08-26-2009, 11:03 PM
racerfox's Avatar
no its the gasket right above the oil filter im going to try cleaning it and putting on some rtv and try again
Old 08-27-2009, 05:44 PM
00SSLS1's Avatar
I had the same issue, I ended up breaking the gasket somehow by dropping the pan a bit. I had to replace it
Old 08-28-2009, 12:30 AM
racerfox's Avatar
so the rtv fixed the right side now the left side is leaking
