Weak points of the LS1?
Old 08-27-2009, 06:10 AM
THEhomelessONE's Avatar
Default Weak points of the LS1?
I'm planning on getting an f1a procharger on 8psi soon, and I just wanted to know what were some weak points on the motor. Right now its all stock except for LT headers and ecutouts. I did some research and found the crank could go up to 900-1000. Also the valvetrain should be upgraded but I won't be revving to 6k and I'm leaving the stock cam for now. So do I need pistons, rods, head bolts, rod bolts, etc? I'm hoping for atleast 500whp.
Old 08-27-2009, 09:01 AM
TransAmcoupe98's Avatar
The weakest point in the bottom end is the rod bolts. However, I spun a crank bearing and effed up the whole assembly. I would go ahead and get rods w/ARP 2000 bolts, Eagle 6.125 rods, get the blocked machined out .005'', and a piston built for bost to lower compression. That will make for a strong bottom end.
Old 08-27-2009, 11:36 AM
crainholio's Avatar
The owner, in many cases.
Old 08-27-2009, 02:18 PM
kinglt-1's Avatar
^lol damn!
Old 08-27-2009, 05:01 PM
SOMbitch's Avatar
LMAO
Old 08-28-2009, 01:43 AM
Rods, bolts, and pistons, thanks!
Quick Reply: Weak points of the LS1?
