PP Stage II 5.3/5.7
Originally Posted by XFiveLiter
I'm tryin' to make a decision, need some input. Just looking for some before/after dyno numbers and track times? TIA
I've been doing similar research. As stated above, the ports on the 5.3 and 5.7s are the same designs. The 5.3 is (I believe) 60cc while the 5.7s are 66.67cc. So you can run the higher copression on the 5.3s without worrying about piston to valve clearance so much.
I was told by PP that the LS6 style heads are better with really big cams. I'm looking at 224 to 228 duration so I think I'm going to go with the 5.3 stage IIs. Since the PP LS6 style heads are welded up 6.0l heads they can set them up for what ever CR you want.
...too many decisions.
Hope this helps and keep us posted with your results.
Thanks for the replys. I think I'm going w/the 5.7s milled .030. I got quoted a VERY good price on the '98, perimeter bolt, 5.7s (low price not available on 5.3s).
W/my small cam and the milling, I shouldn't have any PTV clearance issues, should I?
I dynoed 370rwhp, cam only. I would be satisfied w/400rwhp, I think that would get me into the 10s (3250 race weight) in good air.
oh yeah, I believe i was told the perimeter bolt 5.7's were $300 cheaper than the centerbolts
i went ahead and got some centerbolts, cause I want aftermarket valvecovers in the future
