about to heads cam swap need some advice/tips
Old 08-27-2009, 10:07 PM
midge0wns's Avatar
Default about to heads cam swap need some advice/tips
all right, im about to put in a set of ported 243's to stage 1(the heads are fully assembled), with a 233/239 cam.
i have new pushrods, lifters, oil pump, timing chain.
i have 2 questions.
1. Will i be fine with stock rockers?
2. Will i be fine with stock injectors?
its an 04 GTSLO btw.
Old 08-27-2009, 10:20 PM
LSX Mechanic
Damian's Avatar
Yes to both those questions.
Check piston/valve clearance.
Old 08-28-2009, 12:44 PM
midge0wns's Avatar
all right thanks!
Old 08-28-2009, 12:47 PM
ttranssam's Avatar
ya your fine....its quite simple and once the cam goes in......it all goes together super fast??? take pics
Old 08-28-2009, 02:34 PM
midge0wns's Avatar
will do.
