trouble lowering oil panel to install new pump during cam swap
in the middle of a cam swap and i've unbolted 10 of the oil pump bolts like it says in ls1howto, i've pulled on the pan but the thing will not lower at all.
yeah, got those two lower bolts and it "lowered". got past all that now just having trouble getting the front seal out of the cover. when hammered/screwdriver it just cuts the little inside rubber lip.
now, i have never tried to do it this way, but, have you tried to loose the engine mounts and transmission mounts and jack the engine up as much as you need... say like with a piece of 2x4 on the transmission bell housing.
