whats better TEA 5.3L Stage2 or MTI 2E?
LSX Mechanic
From what I understand, the 2E port is just a budget port, and doesn't get all the TLC that their standard Stg 2 gets. Thats why it's cheaper. In that case, TEA's without a doubt. I just made 455 rwhp with my TEA 5.3's. I don't think you'll see more than 410-415 with a good cam and the 2E's.
Per my conversations with Wayne and e-mails with Jayson (prior to purchasing the 2E's), the porting is the same as the "R" heads but with stock seats and guides. All else was reported to be the same. Same springs, retainers and all. I went with the 2E's mainly because reputation and time in the ring holds a lot of weight with me. Otherwise, I was looking at the TEA heads. I would have been happy either way.
If you take the time to copy the flow charts on MTI's website and overlay them the flow is within ~5cfm between the E's and R's. It's a little trickly overlay. MTI verified my suspensions about the E vs R.
FWIW in the end I'm going with TEA 2.5's for my current project.
The MTI heads have held up to a lot of abuse....the TEA's are putting down IMPRESSIVE numbers, but they're always w/the 5.3L heads and higher compression ratio...not saying there's anything wrong w/that but MTI can make almost the same HP w/the 5.7L heads and a lot less chance of detonation. I almost went 5.3's...but decided against....I'm happy with my MTI 5.7's..but they are the Stage 2+R's...with an X1 cam and Jayson did all my tuning.
LSX Mechanic
